Brake pad assembly grease recommendations
Devon Z
Brixham, Devon
99 2.0 Individual
My go to has always been Copperslip, had my tube for years but are there any resent advances I should consider or stay old school?
I have used this for a few years now, it's very good. Copper slip is a bit thick for my liking.
ProSlip Brake Grease
B21
Scottish Borders
E89 35is
FWIW..for cars with electronic systems in and around the wheels BMW forbids copper based greases..the conductive material MAY get into pins and connectors..
I use red rubber grease on the Caliper sliding pins, it doesn't harm the rubbers. For all the sliding contact points on the pads I use copper ease grease to keep the sliding edges on the Calipers slightly lubed. Backs of the pads also get a smear on the backing shim and in particular where the piston contacts the pad, supposedly stops any chance of brake squeal.
