Hope someone can help me out with more questions on this common subject
My car is a 2001 Z32.2 with DSC fitted and has the 2 pressure sensors fitted into the bottom of the master cylinder
I am trying to understand how the logic might work so if anyone can answer these questions I would really appreciate it
1. Fault code ( 5E20) is common when read with my code reader but only puts the 2 warning lamps on occasionally. Does anyone know the logic for the warning lamps to illuminate
2. The warning lamps never illuminate when driving it’s always after a brief stop in the car and the 2 warning lamp come on directly at next ign on. What could be the reason for that?
3. With this fault code is it a very high probability that it’s the sensor and not a real system fault with some part of the master cylinder. The BMW price for the sensor is a couple hundred quid so I would probably replace it with a good make aftermarket part.
A new master cylinder will is also very expensive so I want to get the correct diagnosis before changing anything
Appreciate any help
Thank you
Appreciate any help
Thank you
