Carly Adapter
A. Gammon
Caerwent
SDrive 35iS M
I have just tried to connect my Carly Gen II to my daughters E85, having first confirmed it would fit. Unfortunately, whilst it does initial fit the socket, it will not "push-in" all the way. The lights initially illuminate, but as soon as you take your hand away, they are extinguished (and the Carly almost falls out). Do I need a connector/adapter? Should I push it in harder. I am naturally concerned not to break it.
I have successfully used the Carly numerous times on my E89, without issues.
Any one have any advice?
Many thanks.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
I'm thinking you just need to push harder, before you do get a torch and check to see nothing is fouling in the socket.
A. Gammon
Caerwent
SDrive 35iS M
Yes. I was very concerned about causing damage to the socket, especially as it's the daughters car!!
I did look at the internals, but it was raining (inevitably), so was not fully motivated! Will have another attempt next weekend.
handsomejackuk
Australian Zeds
t
is a carly obd adaptor any different to any other obd adaptor..? or is it just different pins..?
A. Gammon
Caerwent
SDrive 35iS M
I only have the Carly device and have not seen the 'adapter', so cannot say. I have spoken to Carly, who assure me, it should fit, but it cannot be located correctly.
pgunter
Winchester
2.2i Sport Zedshed Special
Give the socket a spray with an electrical contact cleaner too. It might be corrosion build up on the connectors pins.
Port Solent.. so a local then. Hope to see you out on a few runs at some point.
A. Gammon
Caerwent
SDrive 35iS M
I can certainly try that, though the car leads a very 'cosseted' life, so damp/corrosion is unlikely.
Look forward to meeting you at the forthcoming events......when ever that is now?
pgunter
Winchester
Keep an eye out. Several are always up and planned.
DannyGartside
Wakefield, West Yorkshire
Z4 2.0i Sport
So I got the full carly app yesterday and it didn't want to connect at all, what am I doing wrong
Brian H
Killin
Have you got lights on the adaptor? I assume you have found the adaptor in your device wi-fi settings? What was the issue of it not fitting?
DannyGartside
Z4 2.0i Sport
It's connected to the car ok... The light is showing. I've got it plugged into my phone and the phone starts carly as I knows a USB device it fitted but then in the carly app it says it can't connect
DannyGartside
Z4 2.0i Sport
I might try deleting the reference to the USB connection to it has to create a new one. It looks to connect via USB 1 in the app but then Carly says "can't find connection USB 3"
Are you using the Carly adapter and software? Or another brand?
Once connected in the app you need to connect the software in the bottom right.
DannyGartside
Z4 2.0i Sport
I'm using the carly app but an obd cable I already have. It connected fine y before it bought the full app but obviously it couldn't do anything
Assuming your connecting the software to the car correctly I would say its the cable your using. It needs to be a gen 2. But even if it is you should still get limited functions.
I got the USB adaptor from Carly and works fine just plug and play, it was around £12 I think,
DannyGartside
Z4 2.0i Sport
Hi doing that. I've got the full app too... It started to connect the first time but was taking ages, now it days it can't connect
That's cheap, I've only seen them for about £30.the one I have I bought for my bike but is the same obd plug and it's connected before
Ah yeh sorry I'm getting my purchases mixed up, just checked it was indeed £30 :sorry:
