Looking to install new crankshaft sensor on a 2000 z3 2.0l. Can anyone advise is there much to it? I recently replaced both camshaft sensors and 1 of them was an original so for peace of mind going to replace crankshaft sensor.
Hi, did you have any symptoms, like rough idle or Engine failure??? I said this as my friends Z3 recently cut out whilst driving and he seems to think it is the Camshaft sensor!Looking to install new crankshaft sensor on a 2000 z3 2.0l. Can anyone advise is there much to it? I recently replaced both camshaft sensors and 1 of them was an original so for peace of mind going to replace crankshaft sensor.
There are alot of videos on YouTube about replacing theseHi, did you have any symptoms, like rough idle or Engine failure??? I said this as my friends Z3 recently cut out whilst driving and he seems to think it is the Camshaft sensor!
Yep there different real oem bmw website will give you orginal part numbers you just need to enter last 7 digits of vin. Also get a code reader as these sensors normally flash a code. Don't buy cheap sensors buy oem I learnt the hard way. I replaced both sensors and also changed the vano seals. Totally transformed the car.Having similar problems!
Also, I haven’t searched for vin plate yet, any idea where it is?Yep there different real oem bmw website will give you orginal part numbers you just need to enter last 7 digits of vin. Also get a code reader as these sensors normally flash a code. Don't buy cheap sensors buy oem I learnt the hard way. I replaced both sensors and also changed the vano seals. Totally transformed the car.
ok cool thanks for this! How do I find that website? Is there a link or url you could post here? Sorry, completely new at the z3bmw game!
At the bottom of the windscreen , usually left side.Also, I haven’t searched for vin plate yet, any idea where it is?
Found it in engine bay!At the bottom of the windscreen , usually left side.
The easy one to get to is the exhaust camshaft position sensor, the inlet one (usually the one that fails most often) is more difficult to change. I wrote a “How to ..” guide which explains it.Pretty immaculate condition! Had a look at the camshaft sensor at the front, the one you can actually get at (is that intake or the other one?). Sensor bit looks ok, but the wire with the plug that plugs into it, the plastic/rubber wire sheath is crusty and brittle. Could this be the problem? Would just like to replace the whole thing, but looks like a lot to dismantle to get at the other one! Is it as terrifying as it looks or actually ok if you take your time?
