ECU Trouble ?
Iain C
Ayr, Scotland
Z3 2.2 Sport
So was doing some checking of fuses today for a potential mod and been a bit ham-fisted as now have dash warning lights and the following errors on my code reader. Could kick myself…. :banghead: Do I now need to find a coder like BMW Scanner 1.4 (and the appropriate vintage laptop) to be able to delve/correct further or admit defeat and take car to local mechanic ?
Grateful for any help.
Will they not delete Ian.
What were you doing to cause the issue.
Stephen
Iain C
Ayr, Scotland
Z3 2.2 Sport
Hi Stephen, no they won’t erase - keep coming back. I was looking at some fuses and I must have shorted out fuse 28 (which is normally blank). Seems it covers:-
Starter motor
Automatic transmission
Engine control unit
Cruise control
Immobiliser
Guessing ECU must be alive as can read info streams from it but calibration/settings must be upset.
Try disconnect the battery for 10 mins ( check fuses while disconnected) then reconnect and try clear the fault
Iain C
Ayr, Scotland
Z3 2.2 Sport
Will do Stephen - thanks for coming back. Will probs leave battery disconnected overnight and see how it is tomorrow.
Iain C
Ayr, Scotland
Z3 2.2 Sport
So battery back on this morning but sadly no change. Still got all the same error codes. INPA may be needed to recalibrate perhaps…. 😔
Don't know if our Bosch diag devices would maybe help certainly can give a shot if you like.
Iain C
Ayr, Scotland
Z3 2.2 Sport
Will give INPA a try when I get a cable. Can’t think of anything else at mo. ECU must be ok as its giving me other info and let me remove other errors…
Iain C
Ayr, Scotland
Z3 2.2 Sport
Thanks Stephen - maybe take you up on that. Will try laptop route and let you know. Cheers mate.
