Lights not working
FourReds
Z3m roadster 2000 gauge lights,right tail light, front right side light, and gear shifter light all not coming on. Changed fuse and it keeps blowing. Any suggestions welcomed. Tx
matter of finding the short circuit that's blowing the fuse. Disconnect each unit one at a time to see if fuse stops blowing when it does you will have found the short. Check all wiring serving each unit for damage that could also be the cause of the short.
NZ-Coupe
New Zealand
M Coupe (S50 b32)
I am having the same problem at the moment! I will update if I find anything. I think mine is the light for the oil temp as that's the only thing not lighting up.
