lowest rear lowering springs
darcy
West Yorkshire
z3 1.9 (M44)
Hi all. I've got my front end about as low as I like it but the back is still too high
What's the lowest lowering springs people have found for the teat of a zed?
Currently got a cheap coilover set on with no adjusters and have about a 1.5-2" arch gap...not good.
I want lowssssss!!!!
(Tyres are 40/17")
Cheers
Darcy
Antm72
South Yorkshire
Can't get a great pic in the garage but mine is at tread top20151027_214154.jpg 20151027_214318.jpg
You wouldn't want any more it sits just right for me
Reactions: Rha
Antm72
South Yorkshire
Thing is it doesn't at all the rears haven't caught at all in 300 odd miles they have been fitted.
It was that T-rex that was chasing me Ant. Well that's my excuse, thanks @Andy McDonnell .=)) Yours looks spot on to me Ant.
Antm72
South Yorkshire
18's 7.5jj 225/40/18 around offset 35 spaced at the rear a further 20mm.
darcy
West Yorkshire
z3 1.9 (M44)
Half inch higher than me I'm on
Rear 205/40/17
8.5J offset 30
Front 195/40/17
7.5J offset 35
Antm72
South Yorkshire
The cheaper end coilover kits tend not to lower much at all over stock, i had one fitted to my last zed and if i remember rightly i used e36 convertible rear lowering springs to get the rear to drop as was dissapointed with the drop on the kit.
darcy
West Yorkshire
z3 1.9 (M44)
The front will go down to the floor but the rear is rubbish. No adjusters in the rear just the spring and still not really dropped.
darcy
West Yorkshire
z3 1.9 (M44)
Been told I have the right springs. Should lower the car 60mm when fitted with the adjusters. (there from a coilover set) Removed the adjusters and still not sitting low. Can't possibly go any lower with these other than taking out the pads.
DavidM
Ireland
Eibach lowering springs on mine - 40mm drop. 20mm spacers rear and 5 mm front. I get the odd rub if I go over speed bumps too fast otherwise fine on various surface roads.
Tyres: 225x40ZR18.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
The rear doesn't go low at all with the springs that come with the cheap coilover kits, its pretty pointless even fitting them. Better to find a different pair of rear lowering springs, but most of the sets don't go that low if your after a slammed look.
littlefeller
evesham
just stick a fat bird in the passenger seat, problem solved for free:woot: on a more serious note though my rear is sky high on 18 35 245 does it effect the handling to drop the rear? my missus would kill me if used a fat bird so thats out of the question for me.
Antm72
South Yorkshire
Tyres: 225x40ZR18.
Thats the same as my set up the odd catch but all front and most people trim the arch liners. They never come close to the arches.
As said the rear springs on the cheaper coilover kits will give no drop as a few have experienced including myself .
yocky z3 2.0
Cudworth barnsley
Z3 2.0 roadster
Hi darcy I have a new set of springs 30mm front and 40mm rear was only on car about four months they dropped the back end to just above the tyer you can have them if any good to you cheers Tony.
