I have a nightmare issue with my 2000 2.3 Z3 I purchased a few months back.
It was running great until about a month ago when I came home and the battery was dead. I got it charged up and reconnected the battery to see that the instrument cluster was already lit up and the AC blowers were on (but not the radio) with no key in ignition. I go to start the car and it starts but has an extremely rough idle. If I remove the key the car continues running roughly like nothing happened. Basically, the car thinks the key is in the ignition ALWAYS.
I have tried everything I could find online: checking for a bridge in the instrument cluster, unplugging the ignition switch, unplugging the DME relays and checking fuses, and today I unplugged the entire DME with the instrument cluster still being on when battery is connected.
I am assuming there is some sort of short somewhere because the car does leak and was parked outside for a few months before I bought it. I removed the entire interior trying to find any obvious wire damage but haven’t seen anything yet. There was about an inch of water on the floor and the foam on the carpet was soaked when I removed it. Airbag crash sensors have obvious corrosion. I did find that removing fuse 34 shuts off the DME fan and instrument cluster and 23 shuts off the DME fan and some of the lights on the cluster. Both fuses are labeled as ‘Connector for optional extras’ although 23 is also tagged with several other functions. I believe the car has some sort of aftermarket locking system because it makes a very unique chirp when locking/unlocking.
Has anyone seen a similar issue or have any recommendations of where to look??
