Seat lowering
RoyvL
South African Zeds
Cape Town
My first thread. :)
I have searched through the forum and see it seems to be a common complaint.
Lack of adjustment in the seats and steering column. I have the sport seats.
My problem is I am tall in the torso and with the seat at its lowest and furthest back I have perfect hip to pedal fit but the steering wheel sits across the top third of the instruments and I am looking through the top of the windscreen.
It is also disconcerting as the A pillars and rearview mirror get in the way when cornering.
I would also like to keep the seats as they are in superb condition. And I like to keep it as stock as possible.
Is there any way of lowering by removing and rebuilding the seat squab? Or, a method of altering the frame under the seat?
Anyone done this?
Thanks in advance
RoyvL
South African Zeds
Cape Town
All I found while searching was the spacer fit under the rails on the front of the seats.
While this is good for the angle the squab, and I have done this, it does nothing for the overall height
littlefeller
evesham
ummm think that is the mod I was thinking of, though im sure he posted something regarding the seat foam too.
It may be that the manually adjusted seats might go lower as there's less clutter (motors etc.) under them. Of course you lose out on electrical movement.
littlefeller
evesham
who needs electric seats anyway, its the electrical movement that breaks the seatbelt guides, this is why its usually the passenger side that gets broke.
5harp3y
only way to lower the seats will be to fit aftermarket seats on flat rails
Dino D
Kent
2.8 Manual
Are your seats lower @Dino D ?
Yep but they are Sparco seats with different bases.
Quite a bit lower and can go lower still if I remove the fore/aft adjustment rail.
I thought about trying to lower the standard seats as I really liked the look but the only way I can see is:
Remove seat motors and make new brackets (but how to adjust fore/aft? Or fix position maybe. The back rest adjusts manually anyway.
Replace seat cushion with less padding (but lose the looks which sort of defeats the purpose I guess).
I think a member in Norway made his own bases for some aftermarket bucket seats. The bucket seats are relatively cheap (and you can easily fit seat heaters which I’ve done) but the bases are expensive or else make your own. Maybe cannabilise a scrap Z seat base to make it easier!
Eek
Hi Guys,
First post here on an old thread, but maybe it can be useful for some of you.
I own a Coupe and the seating position also bothered me a bit. I'm 1.90 m (about 6"3), and would bump my head occasionally on the roof (no sunroof) with high speed bumps, but also cramped a bit to clearly see under the rear view mirror and roofline.
I'm currently re-doing the seat rails - it will loose the electric adjustment - and will be fixed in one position. (You can slide the seat a bit front/back if need by loosening with a wrench, hence the slots in the rails) The backrest can still be tilted and uses the OEM handle/cover, that has been trimmed on the bottom a few mm, to clear the rails.
Materials used: approx 150 cm of 50 x 20 x 3 mm tubing + some hexbolts and 8 mm studs.
The front nuts are easily accessible, but the rear bolts needed to be secured underneath the car. And by using m8 instead of m10, the only change to the car was drilling 2 holes in the bottom.
Still work in progress, and I will upload some more pics when available. I haven't measured it yet, but the seat is approx 3 inches lower now, and I might put some spacers under the rails in the front, to give it some extra tilt backwards. I'll also put some spacers under the steering column bracket, that will lower the steering wheel a bit.
Cheers, Kris
gottaz3
Hi Guys,
Cheers, Kris
View attachment 205913View attachment 205909
I have similar problem. Head clearance okay but left knee bashes wheel when changing gear. thinking about lowering seat. Can you give me an update on your modification especially regarding knee clearance when using the clutch.
Sea Ranch
Hello. We have now sold on our 1997 1.9L Z3. But I did lower the passenger side seat. Our car had power seats (fore-aft) both sides. Driver side had power height adjustment. Passenger side did not.
I lowered the passenger side as my wife uses a very thick medical cushion and she just sat way too high. Even with the lowering, it was too high, but alas that was all I could do.
The problem in this area (in my opinion) with the Z3 is that the body styling has the door height swoop down too low and thus you don't feel like you are seated "into" the car as much as on other body shapes where the top of the door is higher.
Anyway, back to lowering the passenger seat . . . the only thing you can do is remove the power adjustment mechanism entirely from the seat. Then make up mounting plates to attach the seat frame right down on the carpet. Not too difficult, but it does mean a bit of fabricating of the two plates for mounting. No welding necessary. Just flat stock and drilled holes.
I arranged it to have the seat fixed as far back as possible and the loss of fore-aft adjustment is not a problem (in my opinion) for the passenger. I would have done the same mod for the driver side, as I wanted to sit lower, too. But the car was very occasionally driven by others. I wanted to retain the fore-aft so that others could drive it.
Hope this help, YMMV, et cetera.
If you'd like a pic of the plates I made, let me know, but really you just have to pull that seat and remove the mechanism and examine the attachment points (seat frame to adjustment mechanism) and decide for yourself how you'd like to to it.
Purplexity
yeah sure, send me some pics of the brackets
Yikes. Ok.
thank you for your continued research!
With all the electronics below the seats, it’s tough to modify race seat rails to work with the factory seats.
id101
Yikes. Ok.
I can imagine plus im not remotely technical. I was hoping some industrious fellow would come up with something. I'd resigned myself to eventually replacing my seats amd just bolting a new one to the floor as I never actually move mine as it has to be all the way back
