Wheels and how much do they weigh
MartinN
Stevenage
2.0Ltr Roadster
Hi Zedders,
I presently run style 18 17 inch square set up.on my Z3, its used for sprints & hillclimbs do weight is important.
Is there a list of, or any one with the knowledge of what Z3/BMW wheels would weigh. I would like to keep to 17's as they are a decent profile. Im down to just about 1120Kg now, the car not me😁
Mazza
Bognor Regis
Z3 1.9 M44 Roadster Z3 2.8 Project
Dont know if this will help but…….
Look at bmwstylewheels.com
section Z
Section Z3-E36
if you open up the file for each wheel it gives the weight in kg. ( last column)
John_B
Derbyshire, UK
Z3 2.8 pre-facelift (Izzy)
I have Style 68s, supposedly these are on the lighter end of the spectrum
Bmw wheel styles as saud above could be a help.
So if you are running a square style 18
That should be 4x 7.5j x 17 et41 if so those wheels are listed as 10.80 kg each.
Now John's style 68 above only available as staggered set
So front are 7.5j x 17 et41 weight is 9.50kg
Rear is a 8.5j x 17 et50 weight 9.92 kg
So yes with a bit of hunting around i reckon there's a potential to obtain a set of 17 and shave a few kilo .
Toby
N.E Lincs
People under estimate the impact heavy wheels have - the rotational weight can give significant weight saving with a lighter set of wheels. Giving a massive handling difference, as well as fuel saving and braking.
Personnally I'd look round for an after market set of forged wheels, rather than cast as this is where significant savings can be made, if you want a lighter wheel.
Mine - I know non Z, but the principles the same fronts 16 inch weigh in at around 5kg, and rears 17 inch in at around 6kg. The rear tyres weigh 10kg a piece, so the wheel is less than the tyre. Something many tyres fitters are amazed at :cool:
Mazza
Bognor Regis
Mine - I know non Z, but….
If you need to re badge it …to join ‘us lot’ ( anagram ? 😋😋). ……I have these for you …. =)) =)) =)) =))
MartinN
Stevenage
2.0Ltr Roadster
Thanks do much for your input and responses folks, much appriciated.
Again Zorg excels
M
