hot air
phil.a
redditch
z4
hi i found a site called pelican it covers a lot of things related to z3s it also covered the heater valve and in it there is a arrow shaped piston, if this sticks it will cause the car to blow hot air all the time, in yankie land you can get a repair kit, not seen one over hear,
AussieZ3
Australian Zeds
Australia
Z3 Roadster
I have seen a repair kit advertised for the heater valve but I believe the kit is for a different model valve. The valve fitted to my Z3 is sealed and cannot be repaired. I am not sure if a repairable valve was fitted to cars delivered to UK. This weekend my AC stopped working and I am beginning to suspect the temperature controller. I will be getting the gas pressure checked on Wednesday and I know for sure that the controller does not supply current to the valve regardless of which zone the pointer is located.
Dimitris Flo
Thanks guys just read up on the post I was about to order a Cable but it looks like I should check a couple other things first....
