Mike’s Retrofit Aircon Cruise Heated Seats ++
OK so I get,
Ignition off - the only pin with 12v is pin 30, nothing on the others.
Ignition on - the only pin with 12v is pin 30, nothing on the others.
Ignition on & Aircon switched on 12v on pin 30 and pin 86, nothing on the others.
Ignition on & Aircon switched on & Engine running 14v on pin 30 and pin 86, nothing on the others.
At least my alternator is fine :whistle:
Happy to recheck if it is not what you expect, got a bit soggy on the drive in not so sunny Bolton.
Excellent- thank you and sorry you got wet!
We’re away in The New Forest celebrating our 40th wedding anniversary with the family this week so I won’t be able to check until Saturday.
Out of interest did you try checking from 12v positive to these pins as I think ( but am not sure) that switching the Aircon on could create a route to earth which would only show if you tested against the positive rather than to earth?
Don’t worry if one, or more, show floating values of voltages - this can be normal. The one I’m looking for is to show 12v to a pin that is a switched earth when the Aircon is switched on.
I'll try later in the week from the 12v positive jump start post under the bonnet to earth on the pins to see if there is any difference that way.
Brilliant , thank you.
I’m hoping that pin 85 changes to earth giving -12v from the positive terminal when you switch the Aircon on?
(No rush - I’m not back until Saturday.)
MickyG,
Please disregard post 161 completely.
My mistake I got the relay positions confused when turning over the relay to check terminal numbers.
I have now checked again (double & triple).
The image below should help, the relay terminal numbers are how the socket looks as you look directly at it with the relay removed.
I hope that makes sense?
Earth to positive column = earth taken from chassis/body and positive probe into terminal number indicated.
Positive to earth column = positive taken from Jump start terminal and earth probe into indicated terminal number.
Again I hope that makes sense.
MickyG,
Brilliant - thank you. I’ll eagerly test my car tomorrow
