Rolling Road remaps
Yeah something's not right. I've done 3 now best one pulling 230bhp. Might be worth checking part numbers on the manifold seeing what you've got.
Mine pulled 195 with a standard manifold on. There is definatley room to get some more bobos out of that @Springers
Springers
Mansfield
Thanks lee when you say check part numbers on manifold, sorry I don’t understand me not being up on these things
Sean d
Lincolnshire
Take a pic and post it on here as its clear if it is the correct one, the inlets are alot wider
Springers
Mansfield
Thanks Sean this is the manifold that Roy very successfully fitted on the car so there maybe a picture there?
I see, I miss read your post, So you've had it dyno'ed to check what its putting out.
When I last spoke with Roy he had a flash map done (upload an existing map onto the ECU) so it's never been live mapped (a map tailored for the engine)
If the part numbers check (which are on Roys build thread) I would look at getting a good Map done.
Springers
Mansfield
It’s the same manifold Lee this is the print out from today if you can make sense of it , it was mapped after it had been on the dyno today
Thanks
Thanks
That's odd because most 2.8's put out around 200 stock. If you look in the zedshed section you will be a big list of cars that have been dyno'ed.
Something doesn't sit right with me, the point of these mods are to gain Hp not make the same power.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
Mine is massively down on torque still compared to yours even after a remap, only 277.7nm which I think is only around the standard figure.
If I'm right if it's 200 at the flywheel its more from the engine? Mine is 195 wheel power and 220 engine power, so if your is 200 at the wheels the engine will be more like 230? There's so many different figures to go by and so many different ways of testing.
Springers
Mansfield
Yeah I am not sure been googling to try to find out wether it's power at the flywheel equates to engine power or power at the wheels is engine power the spread sheet definitely says flywheel?
Could you ring them and ask them to explain it to you?
Springers
Mansfield
Hi Grumps spoke with them earlier and it is bhp at the wheels as on a dyno there not able to measure bhp accurately at the flywheel due to transmission etc so the figure given is at the wheels and they estimate a loss of approx 12 - 15% due to transmission so if you take fig of 199.64 @ the wheels and add you get 224/230 BHP,result coupled with the 365.79 torque well pleased
Springers
Mansfield
I think most places that have a dyno give BHP figures quoted from the engine, looks like yours may be the flywheel power and not engine power so hopefully the correct figure maybe about right.
Hi spoke with them earlier plus another tuner at Chesterfield and it is bhp at the wheels as on a dyno there not able to measure bhp accurately at the flywheel due to transmission etc so the figure given is at the wheels and they estimate a loss of approx 12 - 15% due to transmission so if you take fig of 199.64 @ the wheels and add you get 224/230 BHP,result coupled with the 365.79 torque well pleased
That sounds more like it.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
You're engine is producing close to 235BHP if you've got 199.64BHP at the wheels with a 15% loss or 227BHP if you've only lost 12% efficiency. Either way, they're good numbers
Yes! that's more like it!
Well chuffed, that's a bloody good result there.
