Vacuum leak fix it?
joycem
My 97 Z3 has 250k miles. It just got new plugs, coils, injectors and boot. Now they say it has an air leak which is $700. So am I now in the spot of vanishing returns or do I keep fixing things. It has been great till now.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Check all the intake rubber / plastic pipes for splits. Check the rubbers around the injectors. Easy DIY job to change these and a very common problem on high mileage cars
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
ktnez99
West Midlands
Z3 2.8L
Is this when a “smoke test” comes into its own? Someone with far more knowledge than me may pop along soon to say one way or the other. And hi! Welcome to here @joycem
Smudgemanuk
Bicester, Oxford
2.8l TU pre-facelift z3
Welcome to the forum!
From when I removed the intake manifold off my 2.8tu, I know how bad the vacuum hoses can be
Intake pipes
My post MAF intake pipe has a HUGE hole right in the crease where it concertinas, so that was definitely not helping my engine.
Vacuum pipes
I think this is 2.8 only but.... There are two bits coming off the vacuum unit, which is accessible without taking the intake off, both of those were awful, more holes than pipe. One goes up to the fusebox (as it travels with the with the main loom to the exhaust valve in the backbox) and the other goes up to behind the intake manifold and meets at a joiner in line with where the intake meets the head. Then from there it travels by hard vacuum line around the engine to near the secondary air pump and switches to rubber line (mine was also very perished) before going into the thing with the silver cap (not quite sure what it does but it is near the front offside of the engine). There are also 1-2 vacuum lines relating to the CCV which I changed as they were crap.
I have heard the smoke test works well
It would be helpful for you to add what engine is in your z and location to your profile so people can give specific advice, and saving you retyping it each time. This can be done my clicking on your username near the top right corner and going to account details.
This is a link to a thread to help with parts buying:
Hope this all helps a bit!
Chris.
Hi and :welcome: to the forum from me too in Stafford. Yes a smoke test will find any leaks in the system.
Delk
Hemsby Norfolk
Z3 3.0T
I see smoke testers on the sales sites but how many people have access to one? Just wondering if it's something I am missing in my collection.
AntStark
Hampshire
2002 3.0 Sport
I made my own ..works a treat
AntStark
Hampshire
2002 3.0 Sport
How about doing a write-up for us inexperienced members on “How to make your own smoke tester”? @AntStark
You need a big jar with a lid, a cheap soldering iron, baby oil soaked cloth and a cycle pump. I’ll take some more pics if you are genuinely interested.
ExMX5owner
Moderator
Staff member
Global Moderator
Australian Zeds
Queensland, Australia
That explanation did it for me, Cheers. :thumbsup:
ktnez99
West Midlands
Z3 2.8L
I am! Please.
